A5W4eXCNhzArsec
Oct 27, 2021Aspirant
RAX48 wifi channel changed
https://community.netgear.com/t5/Nighthawk-WiFi-Routers/RAX48-wifi-channel-changed/m-p/2156255 I set the 5GHz channel to 36. After a month, I scan nearby wifi and found out my wifi is on channel 14...
Oct 28, 2021Guru - Experienced User
What are you using for wifi scanning?
Got a screen snip?
What do the actual devices connected to it show when you pull up their wifi specifics?
A5W4eXCNhzArsec
Oct 28, 2021Aspirant
I am using macbook wireless diagnostics to scan wifi.
The wifi channel shows channel 149 when macbook connects to the 5GHz wifi.
- FURRYe38Oct 29, 2021Guru - Experienced User
- A5W4eXCNhzArsecOct 29, 2021Aspirant1.0.3.96
Factory reset done.
I prefer not to factory reset in the future because that will erase my parental control user profiles.- FURRYe38Oct 29, 2021Guru - Experienced User
