A5W4eXCNhzArsec
Oct 27, 2021Aspirant
RAX48 wifi channel changed
https://community.netgear.com/t5/Nighthawk-WiFi-Routers/RAX48-wifi-channel-changed/m-p/2156255 I set the 5GHz channel to 36. After a month, I scan nearby wifi and found out my wifi is on channel 14...
A5W4eXCNhzArsec
Oct 28, 2021Aspirant
I am using macbook wireless diagnostics to scan wifi.
The wifi channel shows channel 149 when macbook connects to the 5GHz wifi.
Oct 29, 2021Guru - Experienced User
- A5W4eXCNhzArsecOct 29, 2021Aspirant1.0.3.96
Factory reset done.
I prefer not to factory reset in the future because that will erase my parental control user profiles.- FURRYe38Oct 29, 2021Guru - Experienced User
https://kb.netgear.com/24231/How-do-I-back-up-the-router-configuration-settings-on-my-Nighthawk-router- A5W4eXCNhzArsecOct 29, 2021Aspirant
Setting saved but not the parental control profiles. I have to reassign device to profile.
