A5W4eXCNhzArsec
Oct 27, 2021Aspirant
RAX48 wifi channel changed
https://community.netgear.com/t5/Nighthawk-WiFi-Routers/RAX48-wifi-channel-changed/m-p/2156255 I set the 5GHz channel to 36. After a month, I scan nearby wifi and found out my wifi is on channel 14...
A5W4eXCNhzArsec
Oct 29, 2021Aspirant
1.0.3.96
Factory reset done.
I prefer not to factory reset in the future because that will erase my parental control user profiles.
Factory reset done.
Oct 29, 2021Guru - Experienced User
- A5W4eXCNhzArsecOct 29, 2021Aspirant
Setting saved but not the parental control profiles. I have to reassign device to profile.
