A5W4eXCNhzArsec
Oct 27, 2021Aspirant
RAX48 wifi channel changed
https://community.netgear.com/t5/Nighthawk-WiFi-Routers/RAX48-wifi-channel-changed/m-p/2156255 I set the 5GHz channel to 36. After a month, I scan nearby wifi and found out my wifi is on channel 14...
Oct 29, 2021Guru - Experienced User
A5W4eXCNhzArsec
Oct 29, 2021Aspirant
Setting saved but not the parental control profiles. I have to reassign device to profile.
