mtammons
Dec 30, 2020Tutor
RAX48 wifi signal seems slow
Replaced old router with Nighthawk AX6(RAX48) router. I have ATT fiber feeding the router. When wired to the router I get between 750 and 900 mbps speed(as expected). However, the wifi speed seems...
- Jan 07, 2021
I haven't seen any devices hitting 80% throughput. its usualy that 55-65%. I've seen the occasional one hitting the 75% ish.
If you're trully wanting faster speeds, you could see if you can swap out your wireless card for a better one. I upgraded my intel 8260 to an intel ax210 (AX) for around that $30. Again, you'd have to check if its compatible with your device.
An example is that my AX210 card will connect around that 2000mbps and just breaks 1000-1100mbps. And thats within 10ft of the router. And I've tried it on arris and netgear routers.
Everyone's is going to be a bit different though. And if you're needing faster speeds than 400mbps, I'd go hardwired anyway. Its basically when you're moving massive amounts of data that you need fast speeds. Gaming/streaming doesn't usually hit >40mbps.
Christian_R
Jan 05, 2021NETGEAR Employee Retired
Hello,
If you recently purchased the device I would recommend contacting our support team as newly purchased devices are provided with 90 days of complimentary support. You may open a ticket by registering your device using the link below.
https://www.netgear.com/support/contact.aspx
Christian
mtammons
Jan 05, 2021Tutor
Thanks for the reply Christian. I’m on my 3rd router and about 10hrs with 4 different “specialist”. I’m hoping someone on here is smarter than their “specialist”
- plemansJan 06, 2021Guru - Experienced User
What att gateway do you have?
What firmware is on the RAX?
What fixes have you tried implementing? (so we don't go over them multiple times)
I've seen many issues with att gateways.
have you tried putting the netgears IP address into the att gateways dmz?
Or even trying the RAX in access point mode and letting the att gateway act as router?
also, what devices are you testing on?
this is another key as a 1x1 devices isn't going to have the same speed at a 2x2 device.something else to keep in mind is the 2.4ghz is much much slower than 5ghz. Especially if you live in a congested area like apartment, condo, town home, or even homes close together. I've got a cax80 and RAX200 (and other brand routers) and my 2.4ghz will hit peaks of 90-100mbps but its average throughput is more along the lines of 50-60mbps because of congestion.
What is the home environment?
And what is it made of? (certain materials block wifi better than others)
- mtammonsJan 06, 2021Tutor
I'll do my best to answer all your questions.
ATT Gateway: Pace model 5268AC.
RAX48 Firmware Version: V1.0.2.72_2.0.45
I'm ok with the 2.4 ghz network. All our efforts are on the 5ghz network. Below are the changes I made with Netgear support.
- confimed that my network adapter will accept the speed. My network adapter speed is 866.1
- changed the mode to "up to 1200 mbps" and set to channel 161,157, and 153. currently on mode "up to 4800 mbps" channel 44
- tried turning off "Enable AX" currently its on
- tried turning on QoS. currently it off
- In the WAN Setup tried changing the MTU size to 1476, 1484,1486, 1492. It's currently back on its default of 1500.
- I have not made any changes to the ATT Gateway
I was testing on my laptop sitting in the same room as the router(5 ft away).Laptop never got higher than 400mbps. I was also testing on my son's XBox in the next room.20ft away. XBox never got more than 150mbps on the 5G network. Those 2 devices were the only things connected during testing. I'm in a single family home on a half acre lot. Not much network congestion. Wall are made of sheet rock(drywall).
Thanks for all your help!
