A5W4eXCNhzArsec
Aug 07, 2021Aspirant
Rax48 wpa3 ssid not saved
My 5ghz guest network is using wpa3. However the ssid got stuck with the old name when I changed to a different name.
Aug 07, 2021Guru - Experienced User
Please explain this a little more in detail.
"its stuck"
are you changing it in the app? In the browser?
How do you know its stuck? or what is telling you that?
- A5W4eXCNhzArsecAug 07, 2021AspirantI tried both in app and web. Same behavior.
Original ssid was aaa. I changed it to bbb and saved. After save the ssid is still showing aaa.- plemansAug 07, 2021Guru - Experienced User
Tried a simple factory reset on it?
- A5W4eXCNhzArsecAug 07, 2021AspirantTried. Same problem afterwards.
