A5W4eXCNhzArsec
Aug 07, 2021Aspirant
Rax48 wpa3 ssid not saved
My 5ghz guest network is using wpa3. However the ssid got stuck with the old name when I changed to a different name.
A5W4eXCNhzArsec
I tried both in app and web. Same behavior.
Original ssid was aaa. I changed it to bbb and saved. After save the ssid is still showing aaa.
Aug 07, 2021Guru - Experienced User
Tried a simple factory reset on it?
- A5W4eXCNhzArsecAug 07, 2021AspirantTried. Same problem afterwards.
- plemansAug 07, 2021Guru - Experienced User
What firmware version are you on?
Are you using smart connect?
- A5W4eXCNhzArsecAug 07, 2021AspirantI’m using the latest available one. I’m talking about guest WiFi so there is no smart connect.
