smith01's avatar
smith01
Follower
Jan 09, 2021
RAx48
The Router will not connect to my cable modem.
How do I get help.
1 Reply
  • michaelkenward's avatar
    michaelkenward
    Could mean anything.
    Does the cable fit?
    What is this modem?
    What are you doing and where does it go wrong?
    smith01 wrote:
    How do I get help.
    If it is a new device, then use support.
    Contact Us | Support | NETGEAR
    Start here:
    MyNETGEAR | Product Registration
    Start a case and, with luck, they will contact you.
    Or provide some useful detauls to people in tnhis community.
    You have posted your message in the section of this community given over to Nighthawk WiFi Routers. (This is easily done, given Netgear's impenetrable community structure.)
    You might get more help, and find earlier questions and answers about your hardware, in the appropriate section for your device. That's probably here:
    Nighthawk Routers with WiFi 6 (AX) - NETGEAR Communities
