ECMS
Jun 27, 2024Aspirant
RAX49 router not forwarding port 445
The office: We have a RAX49 wifi router. It’s the main router for our small office. We only have 2 computers in the office. A SMB server which is wired to the router, and a desktop connected wi...
michaelkenward
Jun 27, 2024Guru - Experienced User
ECMS wrote:
Outside the office:
We can not access the server using the router WAN IP address. We never get the login screen.
Access how?
- ECMSJun 27, 2024Aspirant
Thanks for the reply michael
Access how? We connect from our Macs. smb://0.0.0.0 (the real IP deleted) We don't get the sign on screen asking for account & password.Connect just times out.
oh also adding. I can connect to the server using screen sharing from home through the router.
- michaelkenwardJun 27, 2024Guru - Experienced User
I asked because Netgear has been blocking "remote access" as a security measure.
Perhaps I should have asked about this:
SMB server which is wired to the router, and a desktop connected wirelessly.
You are playing with various things that need to cooperate. In this case, both the server and the desktops need to play nicely together. The router is just one link in the chain.
People need to know as much as possible about what is happening at your end before they can begin to ponder on what might be going on.
- ECMSJun 30, 2024Aspirant
it's a straight forward setup. Nothing special. We access the server in the office fine. DMZ is setup on the RAX49, and it all works. For some reason, only the port for SMB (445) doesn't get to the server from the outside. The RAX49 log doesn't show port 445 coming through either. I have tried multiple computers, and I get the same results. a timeout on the computer. I'm thinking.. the issue belongs to the Internet provider. Maybe they are blocking the port on their gateway, BUT they same no. Wish there was a way I could do a traceroute on that port and see where it stops. I tried. BUT I will continue to plug away at it. THANKS for the reply. Will post the out come when I can,
