Gabnxe
Jul 24, 2024Tutor
RAX5 not broadcasting wifi
Since doing a factory reset, my RAX5 router is not broadcasting wifi. When I tried to log into it directly, I got a splash page that said to use the Nighhawk app, but the app is not seeing the router,...
Jul 25, 2024Guru - Experienced User
A couple things.
1. There isn't an RAX5. Its a 2 digit number at least. What actual model do you have?
2. On the splash page that says to use the app, there's a link at the bottom that says "i don't have a smartphone" or similar. Click on that and you can go through setup through the browser
3. Did the wifi on/off button get hit during the reset? Happens a lot. You have to push and hold it for at least 2 seconds to re-enable the wifi
Gabnxe
Jul 25, 2024Tutor
It’s also called AX1600. I checked the bottom of the router and it says RAX5🤷🏼
I tried the link on the splash page, but it doesn’t work.
I don’t see a wifi on/off switch anywhere.
Thanks.
Thanks.
