Gabnxe
Jul 25, 2024Tutor
RAX5 not broadcasting wifi
Since doing a factory reset, my RAX5 router is not broadcasting wifi. When I tried to log into it directly, I got a splash page that said to use the Nighhawk app, but the app is not seeing the router,...
Gabnxe
Jul 25, 2024Tutor
It’s also called AX1600. I checked the bottom of the router and it says RAX5🤷🏼
I tried the link on the splash page, but it doesn’t work.
I don’t see a wifi on/off switch anywhere.
Thanks.
Thanks.
Gabnxe
Aug 05, 2024Tutor
I was able to get the router set up. I had the Ethernet cable set in the modem jack when connected to a laptop. Thanks for all of the suggestions!
- FURRYe38Aug 05, 2024Guru - Experienced User
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy.
