t1pper
Mar 06, 2021Follower
RAX50 - AX5400 5GHz timeouts
I'm having an issue with my RAX50 and my 5GHz network. My 5G network works fine for any device when that device is newly connected to the 5G network. Then over time the network becomes more and more ...
Christian_R
Mar 09, 2021NETGEAR Employee Retired
Hello t1pper,
If you recently purchased the device I would recommend contacting our support team as newly purchased devices are provided with 90 days of complimentary support. You may open a ticket by registering your device using the link below.
https://www.netgear.com/support/contact.aspx
Christian
