robinmarsh2000's avatar
Oct 06, 2021
RAX50 - Networks not working
My house had a power outage. Since then the 5.0 and 2.4 lights on the router do not light up and there are no active networks from this router. The internet signal is passing through the router to another router in another part of the house.
  • FURRYe38's avatar
    Try a factory reset by pressing the reset button for 10 seconds then release.
    Check the power adapter as well. Be sure it's working.
  • plemans's avatar
    push and hold the wifi on/off button for 2 seconds.
