Wade0004
Aug 09, 2021Aspirant
RAX50 - Refused to Connect to device
My router began throwing up this error ( ERR_CONNECTION_REFUSED ) when I'm trying to access a device from outside my network. Inside the network I can access it fine. And I used to be able to acces...
Aug 09, 2021Guru - Experienced User
What modem/gateway is the router connected to?
What device is this you're trying to access and what program/process are you using to try to access it?
Wade0004
I am using a Netgear CM1000v2 cable modem
The device is a RaspberryPi running a gaming server for FoundryVTT
