rpaxel2
Oct 17, 2022Aspirant
RAX50 5G setup greyed out
I have an RAX50 running FW 1.0.11.112. 5G wireless is no longer working, when I go to wireless setup it shows the Enable SSID Broadcast box checked but it's greyed out, like something else is overri...
- Oct 17, 2022
Well, I think I found the issue, I selected Enable Smart Connect and it must have greyed out the 5G setup area. I unselected it and my 5G setup is active now.
Oct 17, 2022Guru - Experienced User
Is smart connect enabled on the router? Try disabling smart connect...
