dave9398
Nov 27, 2022Aspirant
RAX50 5G stops working
Hello, I have been using my RAX50 router for approximately 1 year with almost no issues but lately the 5G SSID broadcasts but my devices cannot connect to it. I have restarted the router a few times...
Kitsap
Nov 27, 2022Master
dave9398 wrote:Hello,
I have been using my RAX50 router for approximately 1 year with almost no issues but lately the 5G SSID broadcasts but my devices cannot connect to it. I have restarted the router a few times and that works but the last restart took a physical power cycling to work and it was less than a week since the last restart. I am on firmware version V1.0.12.120_2.0.83 which seems to be the latest. 2.4 is still working fine but I have a fiber line and the lower speeds from 2.4 is disappointing (and the reason I moved to the RAX50 from the provided CenturyLink router was because of speed and coverage).
Thanks for any ideas,
Dave
Perform a firmware default reset before and after you re-flash the same version of firmware that is already flashed. Make sure you flash the firmware from a web browser on a computer directly connected to the router via an Ethernet cable.
It is possible you have a hardware failure.
Are the devices you are trying to connect based on iOS? Windows? Android?
- dave9398Nov 28, 2022Aspirant
The devices are all of the above IOS, Windows, and Android tv with the same issue. I will try and do the reset when I have some time to reset all of the customization I did to set the vlan etc. for CL.
Thanks for the suggestions
- KitsapNov 28, 2022Master
Please confirm your Wi-Fi indicator LED's are illuminated.
Does your 5 GHz SSID and password differ a great deal from your 2.4 GHz SSID and password? There is a chance what is accepted by one device is more than another can accept. For a test, go back to the Wi-Fi SSID and password printed on the nameplate.
When a device does not connect, you may have to forget the network on the device and re-enter the password.
