dave9398
Nov 27, 2022Aspirant
RAX50 5G stops working
Hello, I have been using my RAX50 router for approximately 1 year with almost no issues but lately the 5G SSID broadcasts but my devices cannot connect to it. I have restarted the router a few times...
dave9398
Nov 28, 2022Aspirant
The devices are all of the above IOS, Windows, and Android tv with the same issue. I will try and do the reset when I have some time to reset all of the customization I did to set the vlan etc. for CL.
Thanks for the suggestions
Kitsap
Nov 28, 2022Master
Please confirm your Wi-Fi indicator LED's are illuminated.
Does your 5 GHz SSID and password differ a great deal from your 2.4 GHz SSID and password? There is a chance what is accepted by one device is more than another can accept. For a test, go back to the Wi-Fi SSID and password printed on the nameplate.
When a device does not connect, you may have to forget the network on the device and re-enter the password.
