jp256
Jul 31, 2026Aspirant
RAX50 5GHz not connected to internet
RAX50 suddenly lost 5GHz connection to internet. 5GHz signal is rated "excellent" by client devices but client devices using 5GHz network can no longer connect to internet. 2.4GHz works fine and clie...
HappyCat
Jul 31, 2026Luminary
Honesty, I have no idea whether updating the firmware, or doing a Factory Reset will fix this WiFi issue. However...
- I do not see how it can be worse than doing nothing. If you do want to "go back", just download the previous firmware and perform a manual firmware upload. (going 'down' is the same as going 'up')
- If the RAX50 remains within the 1-year hardware warranty, Netgear is not likely to approve a replacement unless the router is at the current firmware level.
