jp256
Jul 31, 2026Aspirant
RAX50 5GHz not connected to internet
RAX50 suddenly lost 5GHz connection to internet. 5GHz signal is rated "excellent" by client devices but client devices using 5GHz network can no longer connect to internet. 2.4GHz works fine and clie...
Aug 01, 2026Guru - Experienced User
jp256 wrote:RAX50 suddenly lost 5GHz connection to internet. 5GHz signal is rated "excellent" by client devices but client devices using 5GHz network can no longer connect to internet.
Are they getting IP addresses from the router?
Can you ping 1.1.1.1 ? If you can, then the problem likely is related to DNS.
