MM50
Mar 15, 2022Aspirant
RAX50 Advanced Tab Not Working
RAX50 running V1.0.10.110 and Advanced Tab is visible but does not work with any combination of ipad/iphone and browser that I can find. Advanced Tab is only works from my windows laptop. I did a h...
Mar 16, 2022Guru - Experienced User
Try going back to first FW version or a few versions after 1st version release?
MM50 wrote:
RAX50 running V1.0.10.110 and Advanced Tab is visible but does not work with any combination of ipad/iphone and browser that I can find. Advanced Tab is only works from my windows laptop. I did a hard reset of router and multiple reboots of all devices but not working. Any suggestions?
- dmitch77Mar 16, 2022Star
Given the fact that the oldest FW version in Netgear's site is 1.0.5.106, and that that version also has the bug we're talking about, Netgear has made it quite difficult to revert to a working version. Not to mention the fact that the bug prevents access to the router's admin page that allows you to load a FW version from a file.
- FURRYe38Mar 16, 2022Guru - Experienced User
Actually here is v1.0.0.x and v1.0.2.x versions available on the RAX50 support site...
You are right, I missed that disclosure triangle. Anyway, I am unwilling to skip the recent security fixes so I'll just stay with the latest version with a broken UI.
