MM50
Mar 15, 2022Aspirant
RAX50 Advanced Tab Not Working
RAX50 running V1.0.10.110 and Advanced Tab is visible but does not work with any combination of ipad/iphone and browser that I can find. Advanced Tab is only works from my windows laptop. I did a h...
dmitch77
Mar 16, 2022Star
Given the fact that the oldest FW version in Netgear's site is 1.0.5.106, and that that version also has the bug we're talking about, Netgear has made it quite difficult to revert to a working version. Not to mention the fact that the bug prevents access to the router's admin page that allows you to load a FW version from a file.
Mar 16, 2022Guru - Experienced User
Actually here is v1.0.0.x and v1.0.2.x versions available on the RAX50 support site...
- dmitch77Mar 16, 2022Star
You are right, I missed that disclosure triangle. Anyway, I am unwilling to skip the recent security fixes so I'll just stay with the latest version with a broken UI.
- FURRYe38Mar 16, 2022Guru - Experienced User
Please send DarrenM a PM and ask about a beta that maybe available. Seems that this was fixed for the RAX45 in a beta so there maybe one for the RAX50.
- DarrenMMar 16, 2022Sr. NETGEAR Moderator
Yes please send me a PM if you would like to try a Beta with a fix for this issue.
Thanks
DarrenM
