khalilkhalil
Jul 19, 2022Guide
RAX50 AX 5400 fails on 5G
This RAX50 has been a nightmare on the 5Gig as it constantly drops. I had it set to smart which selected 2.4 or 5 GHz depends on the device but that was no good either. But now I notice that the 2,4 ...
khalilkhalil
Jul 20, 2022Guide
Can you share the location I can get older FW for this router? The downloads location only has the one from June 2022 which I am using, as well as release notes for older FW but not the FW itself.
Jul 20, 2022Guru - Experienced User
Nighthawk RAX50 | WiFi 6 Router | NETGEAR Support
click on downloads.
then click on +view previous versions
I just checked and it opened fine for me. There's a download button.
If its not showing, try a different browser.
