JustinHolst
Jul 19, 2021Tutor
RAX50 AX5400 - Drops internet connection for short periods (recent problem).
I have been using a RAX50 both for two hardwired PCs and also my mobile/tablet devices. The router is connected via hardline to my comcast cable modem. Starting a few days ago I have been having co...
slackrl
Jul 19, 2021Luminary
Hi Justin:
So far looks like it could be the NightHawk. Since you've connected directly to your PC from your modem. However keep in mind this is just one device tasking your modem. Where as the router though is it one device will task pull more from the modem.
Also do'nt forget each device wired or wireless attaching to your router may also require pataching/updating of OS and Firmware. I would make this my next step.
Afterward should you whish to continue troubleshooting would be to troubleshooting by drill down isolation.
Be patient as this will cost you some time.
(A) Try running the NightHawk with only all the wired devices connected to it and see if drop outs still happen.
If so try isolating by wired devices substracting each wired device one at a time.
(B) Try running the NightHawk with only all the wireless devices connected to it and see if drop outs still happen.
If so try isolating by wireless devices substracting each wireless device one at a time.
The above steps may help you to find if a pacticular device could be causing the problem.
(C) Try putting all your slower older devices on the 2.4 Network and all devices that can run @ 5g or higher on the 5G Network.
Note: You will need to turn off Smart Connect and reboot your router for Section (C) testing.
FYI: Some have found that turning on Smart Connect just slows things down, it appears you lose the speed to your devices of the 5G side of your router.
If all fails and your warranty is in force. Call tech support. If they need to replace the router you will have to get them (after they tested on tier/level 1) to escalate you to tier/leve 2 to declare the router defective and replae the router.
Note: when you feel you have the router set like you want it, make a configuration backup.
That way when you get the exact replacement router and firmware update it to the current version on this router, you will be able just to upload the config file and save you some setup time.
Post back a lest us know how thing work out.
slackrl.
JustinHolst
Jul 20, 2021Tutor
Thank you for this reply. I am in the midst of doing some of this, but also working from home at the same time so can't be disconnecting my main PC.
This morning I ran a test where I forced all of the wireless devices off and had just my two hardwired PCs. I then ran a ping -t on my home pc to google.com. It ran for a good hour or more, out of 7400 pings to google there was a small section of five of them that had request timed out.
I then added my iphone to the wireless network and just put on a random stream, and then did the ping test again from my home PC. Out of 4200 pings I had the same section of 5 request timed out.
I don't do a ton of testing like this so honestly I don't know if it is normal that a ping should be able to succeed 10k times in a row or something. So since kind of both my tests are "dirty" I'm just going to start adding wireless devices one by one and see if it gets worse.
- JustinHolstJul 20, 2021Tutor
I added my Amazon Echo and my phone and just streamed things on both of them and had a ton of disconnect events. Right now my testing leads me to believe that this is a systemic problem with the router, and more use just exacerbates it.
- slackrlJul 23, 2021Luminary
Sounds like your are will be comming to a conclusion shortly.
However did you test the Echo and your phone seperately..
Keeping in mind the Echo and your phone are always on listening devices
unless the disable this feature until ready to use it.
slackrl
