DeathRider
Sep 20, 2021Follower
RAX50 AX5400 Better performance so far with AX disabled.
I have a few week old RAX50 I just bought. Im running into an issue where Wifi 6 connection gets small pauses, wont load images right away, then after a few seconds 5 or less the images load. I have an old Belkin Wifi extender if I connect to that (not Wifi 6) no issues so far. So im going to try to disable the AX in the router and let that run for a few days to see if that helps.
Wifi 6 devices are:
Note 10 Plus
Iphone 11
Firmware on the RAX50
V1.0.3.96_2.0.59
I didnt not factory after the firmware update. Not sure if that was needed. I just upgraded and set it up. Also with AX on reboot the router once a week seem to help for a bit.
Thank you in advance.
No RepliesBe the first to reply
