JConrade
Mar 15, 2022Aspirant
RAX50 AX5400 Dropping Clients - Message that Access Point is temporarily full
My router has been working fine for a long time but suddenly has started limiting clients connected. I have smartconnect enabled but only 14 devices are connecting at a time, including the 5 wired d...
Mar 15, 2022Guru - Experienced User
1. what firmware is on the router?
2. what modem/gateway is the router connected to?
3. what is giving you the notice of it being full?
- JConradeMar 17, 2022AspirantFirmware v1.0.10.110
Connected to the fiber modem as it has since initial install (not sure of the modem information)
Phones will show that message when connecting now and half of the TV's in the house won't stay connected and have to be rebooted a half dozen times to actually gain access. Searches and signal get very slow at random times. Nothing has changed, the settings are the same as my initial setup. This happened several months back as well for about 1 month and now happening again. The best explanation is cycling.- plemansMar 18, 2022Guru - Experienced User
What fibre gateway is it?
Did you try factory resetting the router?
- JConradeMar 18, 2022Aspirant
It is a Trendnet TFC-1000mga converter.
I have not factory reset the router but I can. I had no issues at all for almost a year and but now the issues linger and don't have any rhyme or reason.
