Retired_Member
Oct 04, 2020RAX50 AX5400 question 2
Why would one iPhone be on 2.4ghz and the other on 5ghz? They are exactly the same except for color. I do not have smart connect enabled and cannot seem to enable it. But that has to do with only 5gh...
- Oct 05, 2020
I'd be more likely to trust the browser than the app. But I can't say which it is without actually being there and doing a scan.
Just asking which is right is basically a 50/50 option based on the info you've given.
You can always disable it through the browser and see what happens to the wireless signals.
I'm a fan of using smart connect but you dont' have to.
Oct 05, 2020Guru - Experienced User
If you don't have smart connect enabled, then its the user that selects which band to connect to.
If you set the bands with the same name (and smart connect disabled) then the phone can't tell which its connecting to.
Options?
1. enable smart connect and let the router bandsteer devices.
2. name the ssids something seperate so you can tell the 2.4ghz from the 5ghz.
- Retired_MemberOct 05, 2020
When I login through the app, it says smart connect is not enabled. When I log in through my browser it says it is. Which is correct?
- plemansOct 05, 2020Guru - Experienced User
Well, the app still vascillates back and forth, but I am also a fan of direct login. I disconnected and reconnected my phone and it's now on 5ghz. Thanks for your answers.
