Retired_Member
Oct 04, 2020RAX50 AX5400 question 2
Why would one iPhone be on 2.4ghz and the other on 5ghz? They are exactly the same except for color. I do not have smart connect enabled and cannot seem to enable it. But that has to do with only 5gh...
- Oct 05, 2020
I'd be more likely to trust the browser than the app. But I can't say which it is without actually being there and doing a scan.
Just asking which is right is basically a 50/50 option based on the info you've given.
You can always disable it through the browser and see what happens to the wireless signals.
I'm a fan of using smart connect but you dont' have to.
Retired_Member
Oct 05, 2020When I login through the app, it says smart connect is not enabled. When I log in through my browser it says it is. Which is correct?
Oct 05, 2020Guru - Experienced User
- Retired_MemberOct 05, 2020
Well, the app still vascillates back and forth, but I am also a fan of direct login. I disconnected and reconnected my phone and it's now on 5ghz. Thanks for your answers.
