Ericwig
Aug 12, 2022Aspirant
RAX50 AX5400 SONICWALL FIREWALL QUESTION
Purchased nighthawk AX5400. Ran into installation problem that suggested I call for support. Was told error was associated with to many devices attached to system. Was told that that I was going to be...
Aug 13, 2022Guru - Experienced User
The RAX already has a firewall built in.
Ericwig wrote:
Purchased nighthawk AX5400. Ran into installation problem that suggested I call for support. Was told error was associated with to many devices attached to system. Was told that that I was going to be referred to a technician that would clean up my system and that I need to protect my IP address with SonicWall firewall which I agreed to purchase. It was sold by Geeks on Line entity. When I went on line to investigate SonicWall I noted that it looked like they sell a device that went in line with system not something that was installed. My question is is Geeks on Line an entity that is associated with NetGear and is SonicWall a firewall that works with Netgear router AX5400? Question is was I scammed?
