Ericwig
Aug 12, 2022Aspirant
RAX50 AX5400 SONICWALL FIREWALL QUESTION
Purchased nighthawk AX5400. Ran into installation problem that suggested I call for support. Was told error was associated with to many devices attached to system. Was told that that I was going to be...
michaelkenward
Aug 13, 2022Guru - Experienced User
Looking at the "Geeks on Line" site, if that is what we are talking about, I can't see that it makes any great claims for a Netgear connection.
So I don't know if that is right and how Ericwig got there.
If it is passing off in any way, then it could be something that ChristineT might like to pass on to the lawyers.
Ericwig
Aug 13, 2022Aspirant
I was using the Nighthawk application to install and it got me to a point were it told me that it had failed do to an error and to connect with support. Which I did and connected to an individual who said he was Netgear support named Sam. Sam asked what error was incured and told me my system had been compromised and that he was referring me to a technician which could clean my system up and install an IP firewall called SonicWall. I ended up buying a lifetime support for $549. Which went off pending last night. If legal could help it would be appreciated.
- DarrenMAug 15, 2022Sr. NETGEAR Moderator
DId you get any type of case number from the rep if so I can check and see if you actually spoke to NetGear support?
DarrenM
