Retired_Member
Oct 01, 2020RAX50 AX5400
Just upgraded from C7000 version 1 combo to this router and I expected a bit more. Actually a slight reduction in speed. But my question is does the claim "supports up to 25 devices" limit connection...
- Oct 01, 2020
sorry, its only worth it if your speeds are LESS THAN 250mbps.
So if you have gig service, leave it disabled.
Retired_Member
Oct 01, 2020Product info:
6-Stream AX5400 WiFi 6 Router provides speeds up to 5.4Gbps so you can connect, stream, and download faster to newer mobile devices. Powerful 1.5GHz triple-core processor ensures superior performance for concurrent real-time applications such as mulitmedia streaming, online gaming, and audio/video chats. Engineered to deliver up to 4 times the data capacity over previous standards, WiFi 6 technology with OFDMA, 160MHz channel support, and 1024 QAM vastly improves network efficiency. High-powered amplifiers increase range for reliable whole home network. This next-gen router is recommended for medium to large homes, suitable for up to 25 connected devices.
- plemansOct 01, 2020Guru - Experienced User
You can have more than 25 connected device. Its basically just what their using to classify when to move to a bigger/better device.
IoT devices and lower bandwidth devices aren't going to use much data and hardly impact your system.
for instance, I was running a RBK53 system with over 50 wireless devices. But there wasn't much impact because around 15-20 of those were switches/bulbs/etc.
- Retired_MemberOct 01, 2020
Thank you. It is best practice to enable QoS?
It depends on what speeds you pay for. There isn't much benefit at >250mbps speeds.
