Retired_Member
Oct 01, 2020RAX50 AX5400
Just upgraded from C7000 version 1 combo to this router and I expected a bit more. Actually a slight reduction in speed. But my question is does the claim "supports up to 25 devices" limit connection...
- Oct 01, 2020
sorry, its only worth it if your speeds are LESS THAN 250mbps.
So if you have gig service, leave it disabled.
Oct 01, 2020Guru - Experienced User
You can have more than 25 connected device. Its basically just what their using to classify when to move to a bigger/better device.
IoT devices and lower bandwidth devices aren't going to use much data and hardly impact your system.
for instance, I was running a RBK53 system with over 50 wireless devices. But there wasn't much impact because around 15-20 of those were switches/bulbs/etc.
Retired_Member
Oct 01, 2020Thank you. It is best practice to enable QoS?
- plemansOct 01, 2020Guru - Experienced User
It depends on what speeds you pay for. There isn't much benefit at >250mbps speeds.
- Retired_MemberOct 01, 2020
I am upgrading to Spectrum 1G (940mbps). The appointment is in 10 days. I will enable it then.
