Anonymous
Oct 01, 2020RAX50 AX5400
Just upgraded from C7000 version 1 combo to this router and I expected a bit more. Actually a slight reduction in speed. But my question is does the claim "supports up to 25 devices" limit connection...
- Oct 01, 2020
sorry, its only worth it if your speeds are LESS THAN 250mbps.
So if you have gig service, leave it disabled.
Anonymous
Oct 01, 2020I am upgrading to Spectrum 1G (940mbps). The appointment is in 10 days. I will enable it then.
Oct 01, 2020Guru - Experienced User
