PeterAtZarita
Jun 28, 2026Follower
RAX50 Bug: Advanced Access Control Table Cache Corrupted on 2.4GHz for Months (Firmware v1.0.17.142)
Hi everyone, I am posting this here in hopes that a Netgear Community Moderator or Engineer can escalate a severe, ongoing firmware bug affecting my Nighthawk RAX50 running firmware version v1.0....
Jun 29, 2026Guru - Experienced User
Is the iphone the only device effected by this?
Is Smart Connect enabled or disabled?
Set a IP address reservation for the iphone?
Has a factory reset and setup from scratch been performed since last update?
Have you tried v.144 FW?
https://www.netgear.com/support/product/rax50
Make contact with NG support:
