PeterAtZarita
Jun 28, 2026Follower
RAX50 Bug: Advanced Access Control Table Cache Corrupted on 2.4GHz for Months (Firmware v1.0.17.142)
Hi everyone, I am posting this here in hopes that a Netgear Community Moderator or Engineer can escalate a severe, ongoing firmware bug affecting my Nighthawk RAX50 running firmware version v1.0....
Jul 21, 2026Guru - Experienced User
Any progress on this?
PeterAtZarita wrote:The Problem:
When Access Control is enabled, my primary device (an iPhone 14) randomly loses internet access on the 2.4 GHz band and gets kicked offline.
When I log into the router's web admin panel to see what happened, my device is listed under "View list of allowed devices not currently connected to the network."
Technical Details & What I've Tested:
Private Addresses Are Off: On the iPhone 14, "Private Wi-Fi Address", "Limit IP Address Tracking", and "iCloud Private Relay" are all completely turned off. The phone is broadcasting its true hardware MAC address.
The Glitch: The router's 2.4 GHz radio module is refusing to transition the true MAC address from the offline cache back to the active table. It gets permanently stuck in the "allowed but not connected" state.
UI Controls Don't Work: Selecting the device and clicking "Remove from list" or trying to manually "Add" it back fails to flush the routing table. The internal NVRAM database holds onto the duplicate ghost entry and rejects it.
The Only Fixes: The only way to get the device back online is to completely disable Access Control (leaving my network insecure) or perform a painful factory reset—only for the bug to return a few weeks later. This has been happening repeatedly for months.
