Redleg1096's avatar
Redleg1096
Follower
May 02, 2022
RAX50 device priority issues. (RAX50 Firmware Version V1.0.10.110_2.0.75)
I've been looking all throughout these forums for an update on this issue but no one from the actual Help Desk seams to ever respond.
I am unable to update the Device Priority for attached devices.
QoS is enabled.
I've tried numerous updates to the firmware.
I have tried doing both a soft reset and a hard reset of the router.
I've re-configured the router several times.
This issue exists on both of my routers, the RAX50 and the R8000.
Neither router will do device priority correctly.
It used to work fine a long time ago on the R8000 until Netgear stopped using Genie and went to the Night Hawk App.
Nothing I do will change the device priority.
1 Reply
  • FURRYe38's avatar
    There a screen capture of this on the routers web page? Edit out any MAC addresses if seen on the page before posting the picture.
    What browser are you using?
    Is QoS enabled?
