pactum17
Jun 09, 2021Follower
RAX50 DNS Issue
On my RAX50 router I cannot change the DNS settings. Both radio buttons are greyed out. When I do get the option to enter a primary and secondary DNS, the changes will not save and the fields will be...
Christian_R
Jun 15, 2021NETGEAR Employee Retired
Hello pactum17,
If you recently purchased the device I would recommend contacting our support team as newly purchased devices are provided with 90 days of complimentary support. You may open a ticket by registering your device using the link below.
https://www.netgear.com/support/contact.aspx
Christian
