rhammond84
May 19, 2021Follower
Rax50 dropping IPV6
Is there a known bug with Rax50 dropping IPv6 connection? (as it seems for RAX200 here: https://community.netgear.com/t5/Nighthawk-Routers-with-WiFi-6-AX/Firmware-update-1-0-2-98-bad-news/m-p/1954745)...
Romaguera
May 19, 2021Aspirant
Hey all, not sure if this is the right place, since I don't seem as tech literate as this subreddit, but I'm having internet connection problems and no one seems to know how to fix them. Got a new PC, installed Windows 10 Education, all was fine for a bit, and then all of a sudden it can only load google sites. From some searching, this brought me to my IPv6 Connectivity which says No network access. I've tried all the things everybody seems to suggest to no avail: updating drivers, disabling and reenabling, ethernet and wifi, winsock reset, changing my DNS, everything google has suggested.
It's not a router issue because my laptop connects fine, and I have the same problem when using my phone's hotspot on the PC.
