Dave-NHCR's avatar
Dave-NHCR
RAX50 external outdoor antenna
I'm looking for an external antenna that would be used outdoors with the RAX50.  We are having problems with speed and range going through walls.
Thank You
  • plemans's avatar
    what are you actually trying to do? The descrption left a little to be desired.
    Attach an antenna to it that you can run the wires through the wall and have them outdoors?
    • Dave-NHCR's avatar
      Dave-NHCR
      Exactly...we need to run a tablet outside, and right now the range on the RAX50 is being hampered by the outside walls.  I know there are third-party outdoor antennas on the market, but is there one that NETGEAR suggests?
      • plemans's avatar
        No there isn't. Netgear doesn't sell that type.
        Usually you have to find a 3rd party vendor that does have the same matching antenna design and a long enough cable to do what you're attempting.
