rbmisc
Dec 01, 2023Aspirant
RAX50 Firmware upgrade to 1.0.16.132
My router indicates that there is an upgrade for the RAX50 from 1.0.15.128 to 1.0.16.132. Whenever I select to upgrade, it appears to be doing the upgrade and states it's rebooting. When I check my...
michaelkenward
Dec 02, 2023Guru - Experienced User
rbmisc wrote:
I have gone to the support page to see what the latest firmware version is and it is 1.0.15.128 not 1.0.16.132.
So why is my router thinking there is an upgrade for it when there isn't?
There are problems with the way in which Netgear routers detect new firmware. They often say that there is no update when there really is. You seem to have landed on a different issue. It says there is when there isn't.
I see that 1.0.15.128 is a "hotfix". These can be "out of the ordinary" updates that don't make it on to the update servers.
Not sure why that would find 1.0.16.132.
If it bothers you, a couple of things to try.
Manually installed the 1.0.15.128 - Hot Fix, just in case there was some sort of hitch in the previous install.
How do I manually upgrade firmware to my NETGEAR router? | Answer | NETGEAR Support
Reset the router. The factory reset is more a "witchcraft" move than a technically informed solution, but it does seem to fix problems. It is also the first thing that Netgear support will recommend.
Before you do that, save a backup of your current settings.
Then you can restore that if the reset doesn't fix the issue. You can try even if it does. But that can bring back problems.
