wade_w
May 03, 2025Follower
RAX50, i reinitialized NAND flash... HELP ME!
Hello, everyone.
I made a stupid mistake, and I hope you can help me.
When I upgraded the firmware of the RAX50, it became bricked.
I tried the reset button, but it didn’t work.
I tried the TFTP method, but it didn’t work.(learned from https://www.youtube.com/watch?v=_OYNEZuyId0&t=1376s)
I also tried the nmrpflash method, but it didn’t work. (learned from https://www.youtube.com/watch?v=hXhMgQS5k1o&t=1397s)
Using PuTTY software and CP2102 hardware, I successfully connected to the router and was able to access the cef> interface.
(learned from https://www.youtube.com/watch?v=c40x4avo8GU&t=1798s)
However, the tftpd or tftp command didn’t work,they are invalid command. But it works in the video, 29:53.
So, I used the help command to view all the executable commands.
If I remember correctly, I tried the ‘e b’ command, which means reinitialize NAND flash, and now I can no longer access the cef> interface when starting the RAX50.
What should I do?
1 Reply
Might check with the DD-WRT forums to see is someone there knows. Generally thats a very low level issue that only NH engineering has access too. May not be general knowledge here in the forums.
