Richandi
Aug 02, 2020Aspirant
RAX50 Internet LED is red
I have a Nighthawk router, AX5400 6-Stream ("RAX50"). The Internet LED light is red, even though I have internet service. (We are connected through a cable modem provided by the ISP.) Could someon...
Christian_R
Aug 05, 2020NETGEAR Employee Retired
Hi Richandi,
May you factory reset the router and run through the setup assistant again.
Christian
- RichandiAug 07, 2020Aspirant
Thanks, Christian. I may try that -- although, because I have internet service (even though the LED is red), I don't want to do anything that will mess it up!
- CallPaulAug 07, 2020Apprentice
I have a RAX50 with the same exact thing. Internet LED is red and I have internet access.
i just rebooted it and it's been fine.
- ddd345Sep 10, 2020Guide
This is actually for the RAX50 which is not in the drop down list. Same issue as others in this thread. Firmware upgraded (Firmware Version V1.0.2.66_2.0.42) and router rebooted numerous times. LED for internet shows red but otherwise everything is working as expected. Brand new router was installed yesterday.
