Richandi
Aug 02, 2020Aspirant
RAX50 Internet LED is red
I have a Nighthawk router, AX5400 6-Stream ("RAX50"). The Internet LED light is red, even though I have internet service. (We are connected through a cable modem provided by the ISP.) Could someon...
TheeDJ
Nov 29, 2020Aspirant
Same problemas everyone else. It would be nice to see an official response from somebody at Netgear here.
Richandi wrote:I have a Nighthawk router, AX5400 6-Stream ("RAX50"). The Internet LED light is red, even though I have internet service. (We are connected through a cable modem provided by the ISP.) Could someone tell me why it's red, and is that a problem? Again, it is red even though we are getting internet service. Thank you.
Christian_R
Dec 04, 2020NETGEAR Employee Retired
Hello TheeDJ,
If you recently purchased the device I would recommend contacting our support team as newly purchased devices are provided with 90 days of complimentary support. You may open a ticket by registering your device using the link below.
https://www.netgear.com/support/contact.aspx
Christian
- schumakuDec 04, 2020Guru - Experienced User
Christian_R for years the standard on all NGR routers:
The red (or amber) Internet LED does indicate there is an Ethernet link on the Internet/WAN port, however the Internet connection was not established, or the Internet connection check does fail under some strange conditions despite of the Internet is up and running nicely*.
*Wally brain forgot the detail - some special condition (failed ntp date/time? sometimes where PPPoE with authentication is required in combination with a wrong sequence?) can cause this condition.
- TheeDJFeb 21, 2021AspirantI replaced the cable modem provided by Optimum ($10month)with a new Netgear modem ($60amazon)
No red light, improved overall connection and reliability, and it will pay for itself in 6 months.- oakholtMay 16, 2021Aspirant
My model is not as above and is RAX50, but no such model appears on the model options to select.
I have the same problem. The Internet light goes red after the modem and Nighthawk have both been on for a day or more, In my case it is connected to a VirginMedia V3 'super' hub configured in modem only mode. Once it has gone red, streaming services on the VirginMedia TIVO V6 set top box start to fail. I appear to have full Internet access with all other connected devices (over 30 smart home devices) and download speeds are over 200Mbps. I don't think the VirginMedia setup likes the hub to be used in a modem only configuration. The other clue is that once the Internet LED on the RAX50 has turned red, I can then not access the hub 3's web page, which is the default 192.168.0.1. For reference my RAX50 is on 192.168.1.1 and I can always access that. I believe the issue is related to DNS as I use Google's DNS servers configured in the RAX50 and not Virgin Media's DNS servers.
- rpmurph8300Aug 14, 2021ApprenticeI do see it’s not letting me enable anywhere access in the nighthawk app which was working prior to the reset.
