Richandi
Aug 02, 2020Aspirant
RAX50 Internet LED is red
I have a Nighthawk router, AX5400 6-Stream ("RAX50"). The Internet LED light is red, even though I have internet service. (We are connected through a cable modem provided by the ISP.) Could someon...
Christian_R
Dec 04, 2020NETGEAR Employee Retired
Hello TheeDJ,
If you recently purchased the device I would recommend contacting our support team as newly purchased devices are provided with 90 days of complimentary support. You may open a ticket by registering your device using the link below.
https://www.netgear.com/support/contact.aspx
Christian
schumaku
Dec 04, 2020Guru - Experienced User
Christian_R for years the standard on all NGR routers:
The red (or amber) Internet LED does indicate there is an Ethernet link on the Internet/WAN port, however the Internet connection was not established, or the Internet connection check does fail under some strange conditions despite of the Internet is up and running nicely*.
*Wally brain forgot the detail - some special condition (failed ntp date/time? sometimes where PPPoE with authentication is required in combination with a wrong sequence?) can cause this condition.
