Richandi
Aug 02, 2020Aspirant
RAX50 Internet LED is red
I have a Nighthawk router, AX5400 6-Stream ("RAX50"). The Internet LED light is red, even though I have internet service. (We are connected through a cable modem provided by the ISP.) Could someon...
Christian_R
Dec 04, 2020NETGEAR Employee Retired
Hello TheeDJ,
If you recently purchased the device I would recommend contacting our support team as newly purchased devices are provided with 90 days of complimentary support. You may open a ticket by registering your device using the link below.
https://www.netgear.com/support/contact.aspx
Christian
TheeDJ
Feb 22, 2021Aspirant
I replaced the cable modem provided by Optimum ($10month)with a new Netgear modem ($60amazon)
No red light, improved overall connection and reliability, and it will pay for itself in 6 months.
- oakholtMay 16, 2021Aspirant
My model is not as above and is RAX50, but no such model appears on the model options to select.
I have the same problem. The Internet light goes red after the modem and Nighthawk have both been on for a day or more, In my case it is connected to a VirginMedia V3 'super' hub configured in modem only mode. Once it has gone red, streaming services on the VirginMedia TIVO V6 set top box start to fail. I appear to have full Internet access with all other connected devices (over 30 smart home devices) and download speeds are over 200Mbps. I don't think the VirginMedia setup likes the hub to be used in a modem only configuration. The other clue is that once the Internet LED on the RAX50 has turned red, I can then not access the hub 3's web page, which is the default 192.168.0.1. For reference my RAX50 is on 192.168.1.1 and I can always access that. I believe the issue is related to DNS as I use Google's DNS servers configured in the RAX50 and not Virgin Media's DNS servers.
- rpmurph8300Aug 14, 2021ApprenticeI do see it’s not letting me enable anywhere access in the nighthawk app which was working prior to the reset.
