Richandi
Aug 02, 2020Aspirant
RAX50 Internet LED is red
I have a Nighthawk router, AX5400 6-Stream ("RAX50"). The Internet LED light is red, even though I have internet service. (We are connected through a cable modem provided by the ISP.) Could someon...
abustraan
Aug 23, 2021Initiate
Although the category is RAX40 my router is RAX50. Couldn't choose that from the list.
Within the Advanced\LED Settings, I changed the setting from Enable Blinking to Tune off all LED's and then back and that cleared my red internet LED and reset it to white.
- rpmurph8300Aug 23, 2021ApprenticeI’ll give that a try. If that’s the workaround seems to point to some kind of bug in the firmware. I was running 1.0.3.96 but downgraded as the led issues seemed to be one of just several in that release. I’ve since downgrade the firmware to 1.0.2.94 where the issue wasn’t present.
- HermanBJan 07, 2022Tutor
Same issue over here. Newly router suddenly showing red light. Internet is working.
Issued a case at the Netgear support site...curious what the answer will be.
- rpmurph8300Jan 07, 2022Apprentice
Turns out once I updated to 1.0.5.106 the issue appears to be resolved. Been going back and forth with Netgear on this one for almost 3 months. What firmware are you on currently?
