rpmurph8300
Jul 20, 2020Apprentice
RAX50 Latest Firmware Not Available On Web/GUI Update Doesnt't Work
For some reason RAX50 doesnt show up in the model list for this post. RAX50 GUI shows latest firmware is 1.0.2.32. Whats on the Netgear site is 1.0.2.30 (Hot Fix) and it says beta in the title...
rpmurph8300
Jul 24, 2020Apprentice
Is there an ETA when it should be uploaded to the Netgear site? Thank you.
rpmurph8300
Jul 25, 2020Apprentice
The firmware is available on the site as of this morning. One issue i found though is on the Guest Network settings you are unable to remove the check box for "allow guests to see each other and access my local network." I dont know about anyone else but if I'm enabling a guest network i dont want them having access to my local network, just the internet. I've attached a picture for reference. Thank you.
- rpmurph8300Aug 17, 2020Apprentice
Looks like same issue again with an even newer firmware showing up the Router, but is not available on the RAX50 support site. Version is 1.0.2.66. Thank you.
