Wease
Jul 20, 2021Aspirant
Rax50 Loosing internet connection and cant authenticate wifi connection until reset
Every night around the same time my internet drops out, all my smart home stuff stops responding and the wifi access points won't authenticate. The only way I've been able to fix it is by resetting th...
Jul 20, 2021Guru - Experienced User
What modem/gateway is the RAX connected to?
Firmware on the RAX?
- WeaseJul 20, 2021AspirantIt's connected directly to the nbn modem and firmware is v1.0.2.82
- plemansJul 20, 2021Guru - Experienced User
What nbn modem?
NBN is australia's national broadband network.
Its like a mechanic asking what car/motor you have and saying its an automobile.
Sweet. but not helpful.
- WeaseJul 20, 2021AspirantI understand this but my nighthawk is connected directly to The nbn modem (white box on the wall) which does not specify a brand just nbnco so what ever brand modem is supplied by nbn (I'm not sure if you understand the white box on the wall is a modem and all moden/routers supplied by ISP or purchased by the consumer for nbn are setup as a router and not an actual modem as it would be for adsl)
