RAX50
Feb 15, 2022Aspirant
Rax50 Manage Connected Devices
Hello Netgear Community, I have a Rax50 router which I recently rebooted due to some connectivity issues (not a factory reset). After the reboot all my settings were gone as if I did a factory rese...
- Feb 15, 2022
If you press the home button in the upper left hand corner of the nighthawk app, does it list the device as RAX50 (Connected Locally)?
If the device partially lost configs and the app is trying to do a remote connection, it will likely fail until the router gets a full factory reset either via the reset button being pushed for around 15 seconds, or the factory reset via the advanced menu, though a local connection is likely to work.
If it still does not work, then you may need to do a proper factory reset, since it is not normal behavior for config settings to be lost, and as such, is likely indication of some corrupt NVRAM data (A proper factory reset clear it and loads it with defaults).
Razor512
Feb 15, 2022Prodigy
Are you referring to the pause/ resume options in the nighthawk app where internet connectivity can be controlled for each device?
RAX50
Yes.
- Razor512Feb 15, 2022Prodigy
For that function, make sure the app islists that it is connected to the RAX50 when you press the home button in the app, Sometimes if a drvice gets factory reset, and then set up via the web UI while multiple routers or APs are listed in the nighthawk app, it may automatically switch to a different device in the list, even though it still has access to the main router, thus seeing the devices on your network but not having the option to control their access.
Another potential issue, (more common if it is connected behing another router (common in cases where someone gets one of those modem and router combos from a cable provider, and does not set it as a transparent bridge. If the RAX50 gets set up in AP mode, then the access control functions will stop working.
PS if you have multiple APs or extenders, try to conect to the WiFi AP created by the RAX50 directly and run the app so that it establishes a connection with the app locally at least once after a factory reset.As a side note, if the router ended up with any NVRAM corruption that caused some configurations to be lost, it is best to do a proper factory reset before setting it up again fully.
- RAX50Feb 15, 2022Aspirant
I deleted the app and reinstalled it. It sees my router and now makes an attempt to load all the connected devises but gets times out. (Error message - "Request time out. Please try again later. Code:CDIL-API-FAIL".
