RAX50
Feb 15, 2022Aspirant
Rax50 Manage Connected Devices
Hello Netgear Community, I have a Rax50 router which I recently rebooted due to some connectivity issues (not a factory reset). After the reboot all my settings were gone as if I did a factory rese...
- Feb 15, 2022
If you press the home button in the upper left hand corner of the nighthawk app, does it list the device as RAX50 (Connected Locally)?
If the device partially lost configs and the app is trying to do a remote connection, it will likely fail until the router gets a full factory reset either via the reset button being pushed for around 15 seconds, or the factory reset via the advanced menu, though a local connection is likely to work.
If it still does not work, then you may need to do a proper factory reset, since it is not normal behavior for config settings to be lost, and as such, is likely indication of some corrupt NVRAM data (A proper factory reset clear it and loads it with defaults).
RAX50
I deleted the app and reinstalled it. It sees my router and now makes an attempt to load all the connected devises but gets times out. (Error message - "Request time out. Please try again later. Code:CDIL-API-FAIL".
Razor512
Feb 15, 2022Prodigy
- RAX50Feb 15, 2022Aspirant
It says it is connected locally. I will attempt a factory reset UGH. This router has been nothing but issues since day one. Thanks for your input. I will let you know how the rest goes.
The factory reset worked. All functions have returned. Thank you for your help.
