setrio
Jul 17, 2021Aspirant
RAX50 nat moderate and packet burst
Hi, I just bought a RAX50 and I can't get the nat to open in games. Also, I get tons of packet bursts at the point of being unplayable (testing on COD: Warzone). Tried to set NAT to open, ena...
- Jul 25, 2021
I finally just returned the product, it didn't work and support was useless
setrio
Jul 19, 2021Aspirant
none, it goes directly to the wall jack from the internet provider.
Jul 19, 2021Guru - Experienced User
And that jack has something connected to it.
- setrioJul 19, 2021Aspirant
Maybe I explain it wrong, my english is not good, sorry about that. The modem goes directly to the white box on the wall that is just a relay or something like that, there is no router or anything like that between the RAX50 and "the internet".
- plemansJul 19, 2021Guru - Experienced User
that white box has something converting from fibre to ethernet.
Just trying to determine if that "white box" has other functions built into it
I'm pretty sure it doesn't, I checked with the internet provider and they said it shouldn't be a problem. My english is bad but I have some knowledge in the matter, so I'm pretty confident that the "white box" is not the issue. Either way thanks for trying to help, I really appreciate it.
